TwinTurbo.NET: Nissan 300ZX forum - You washed down the last 2 cyl with fuel is my guess. Does
Subject You washed down the last 2 cyl with fuel is my guess. Does
Posted by Jc (Houston) on March 25, 2011 at 2:40 AM
  This message has been viewed 156 times.
In Reply To HELP! no compression on fresh rebuild on 5 and 6 posted by brawndo2505 on March 23, 2011 at 02:43 PM
Message the car run? If it starts the just disconnect those fuel injectors and let it run for about a minute. That should dry out the rings and get a fresh coat of oil on the cyl walls. Also could try doing a "wet" compression test. Spray some wd40 into the cyl. This happened on a motor we built. Dont remember why is washed down but it did. All 6cyl were 0psi compression. Shot a little lube down each cyl and it fired right up.
